elcajonfarms
The dependable, strong Super 55 I have used for mowing and just about everything else somehow slipped a fork and is locked into 3rd or 4th gear. It happened all of a sudden when shifting, there was no noise or grinding and it operates just fine in that gear (no reverse though). It will not go into neutral. The gearshift will move back and foth into two of the usual 8 slots, but the transmission seems to be jammed and kills the engine if you try any of those other two spots. If I go through the trouble of removing the top of the transmission case am I going to find anything I can fix short of a complete disassembly and overhaul of the transmission? Or would I be better off splitting the tractor and attaching the front end with the strong engine to the rear of another Super 55 I have with an old, tired and wheezy engine that has a good transmission and hydraulics?
