TractorLinks.com
Show Parts for Model:
Re: Super 55 Transmission Issues
oliver90owner
07-31-2013 00:54:07
Can you not just remove the stick, re-align the change gates and place the stick where it should be? The end may need building up a bit, to replace years of wear, in the longer term.
You clearly are stuck in one gear and the tranny locks if you attempt to select another at the same time. Fairly common problem on older iron.
elcajonfarms
07-31-2013 12:14:10
 Re: Super 55 Transmission Issues in reply to oliver90owner, 07-31-2013 00:54:07
I don't think you can get at the shifter gates without taking the top off the main case of the tractor, which is a fairly involved process on a Super 55. Have you done what you are suggesting on a Super 55?
Dick W.
07-31-2013 12:32:13
 Re: Super 55 Transmission Issues in reply to elcajonfarms, 07-31-2013 12:14:10
I have done the shift lever removal several times on my 55 and Dad's 70. It is easy to remove and than just get the shift forks into neutral, re-install the lever into the proper slot, good to go!
You may need a long sturdy screw driver to move the shift forks to neutral. You will see all 3 forks lined up when there is an open spot on all 3 next to each other.
elcajonfarms
07-31-2013 15:36:45
 Re: Super 55 Transmission Issues in reply to Dick W., 07-31-2013 12:32:13
OK--I'll give it a try. Thanks
Dick W.
07-31-2013 17:45:37
 Re: Super 55 Transmission Issues in reply to elcajonfarms, 07-31-2013 15:36:45
Don't let the springs fall into the trans!!!!!!!!!!
elcajonfarms
08-27-2013 14:07:34
 Re: Super 55 Transmission Issues in reply to Dick W., 07-31-2013 17:45:37
Once I took a close look at the I&T shop service manual and got a clear understanding of where the forks are, it took me two minutes with a 9/16 inch wrench and a 12 inch screwdriver to fix the problem--forks out of synch. Thanks for the suggestions.
