Anonymous-0
I recently picked up a 1550 diesel. It's my first Oliver and I think it's a great tractor. After mowing hay with it I realized that there is a fuel leak at what I think is the fuel return line fitting to the injection pump. I can't just tighten the fitting because the copper line will kink. My question is whether I can remove the line at the fitting and tighten the fitting and/or seal it with tape? Is it pressurized? Do I have to bleed the high pressure side when done?
Also, is replacing the oil pan gasket pretty straight forward?
