Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 880 and White 2-85 two speed
Ronny L
07-15-2013 19:57:38
Somebody claiming it will "fit right in" is more than a stretch. Can it fit? Yes, will it bolt right in? No. Get a good measurement, and you will see that the frame of the 880 is too short to allow a simple "bolt-in". It can be done given enough time & money. If I recall correctly, you need to gain about 5 inches to allow for the factory radiator setup. Less if you are willing to use an electric fan. But you will need to build a saddle to put between the frame and the transmission casting. Measure your room on the 880, then find a 1600 or 1650 to measure. You will soon see what I am saying. I think you will also have some grind time on the inside of the 880 frame to make a little more room for the hydrapower. Good luck.
