TractorLinks.com
Show Parts for Model:
Re: Oliver 770 Power Steering problems
pcastleberg
07-15-2013 10:36:12
Ok, so I am assuming what I am going to need to do is basically construct a pressure testing gauge to place in the line correct?
I see a 0-5000psi Hydraulic pressure testing gauge at Fleet farm...assuming that's what I'd need. Next question is how do I splice that into the line and then where in the line to I put it?
Assuming the valve goes on the back side of it so I can turn the wheel to make the pump push and then watch to see what the pressure gauge does when the valve is closed?
pcastleberg
07-21-2013 06:44:54
 Re: Oliver 770 Power Steering problems in reply to pcastleberg, 07-15-2013 10:36:12
Ok got the valve setup done with a pressure (3000 psi max) gauge.
Started the tractor and closed the valve...the needle didn't even move, it pushes the ps fluid through when the valve is open but very slowly.
So what next? Does that mean the pump is shot? If so where do I look to get a new pump?
This post was edited by pcastleberg at 06:45:33 07/21/13.
