Formerly PaMike
I am putting a 1755 back together that has been apart for 5+ years. I am also converting it for cab to open station. My main issue is the wiring. It appears the wiring to the front half of the tractor is decent, its the back half that pretty hacked up due to some one splicing in for the cab. I looked online at agco parts book but I couldnt find the harnesses.
-My neutral safety switch is disconnected. I assume that gets wired into the ignition switch
-I have one harness running to the back off the tractor. It is on the right hand side and runs right past the park brake. Is this the only harness that runs to the back? Does it wrap the whole way around the tractor? How do you get wires over to the hydraulic temp sensor on the back left corner of the tractor? Also, does this harness normally have connectors for wires to run up to the lights on the fenders? Or do those harnesses on the fenders run the whole way up to the console and connect in there?
Thanks
Thanks
