Mitch Poindexter
Sorry to keep beating this dead horse, but my service manual for the 3208 showed up yesterday. It is manual SEBR0507-01 for 3208 Industrial & Marine Engines, for SN 75V1-UP and 90N1-UP, which matches the SN's for the 3208s in our tractors. The section for Injection Pump timing gives the same instructions for timing the pump that I used last week to time the pump on my 2-180, but that never worked until we 1st pinned the pump, and then turned the crank backwards (CCW as you look at the front of the engine) until the engine timing pin slipped in (similar to the instructions you gave here).
Sorry for asking what is probably a simple question multiple times, but since its not addressed in the service manual, I'm trying to figure out if your instructions to turn the crank backwards a 1/4 turn then snug the injection pump gear is something that you've learned with experience, or if this is symptomatic of my engine gear train being worn, or something else? Any feedback would be appreciated. Thanks.
