Industrial 80 right foot clutch
I just dragged home a 1947 oliver industrial 80 with a lull 4B loader, didnt take much to get it going again but the right foot clutch takes some getting used to. Got me to thinking what were the last right foot clutch tractors?? 28-44 and 90s had them but up to what years???
my 1947 99 has right foot clutch, and they used the same trans/rear end on the "styled" 99 in 1953 so they might of left the clutch the same but don't know for sure
Our industrial is right foot but our 1953 99 had a left foot clutch. It was the same linkage at the clutch just flipped right to left. The peddle was not the same as the right foot 99 but could be made to work. Im sure the 80 can be made the same just has an extra hole in the floor is all. Duane o.
I have two 80 row crops a 43 & a 47. They both have right side clutch pedals but are totally different from each other. The 47 has a pedal like my 18-28 where you push it forward while the 43 has a pedal that pivots in the same spot but, curves back and ends up right over the trumpet housing. You have to push this pedal straight down. Truthfully, it is a very unhandy pedal to use. I can see why they changed it later.
