TractorLinks.com
Show Parts for Model:
Re: 1850 Oliver PTO Shaft Bearing Number
rrlund
07-09-2013 08:03:52
What bearing are toy talking about? There's a snap ring,then a plug that you pull out with a piece of half inch threaded rod. After you pull that out,there's an o-ring inside those splines that seals the gap between the splines and the plug. The plug is what holds up against the shaft.
eye4iron
07-09-2013 08:55:12
 Re: 1850 Oliver PTO Shaft Bearing Number in reply to rrlund, 07-09-2013 08:03:52
The shaft that came out of the tractor is the approx. 12" PTO shaft that the implement shaft is hooked on to. When it came out there was a bearing on the shaft. The shaft looks like it splines into the rear housing. Once the shaft with bearing is inserted into the rear housing a snap ring holds it into place. The bearing was broke up from the brush hog shaft still turning after it had slipped out. I could not get a number off of it. I did not see a 1/2 " threaded rod.
rrlund
07-09-2013 15:32:33
 Re: 1850 Oliver PTO Shaft Bearing Number in reply to eye4iron, 07-09-2013 08:55:12
OH,OK,I get what happened. I thought it was the one inside on the long shaft. Guess I had that one on my mind since I had to put a whole new shaft in mine last week.
eye4iron
07-09-2013 20:00:15
 Re: 1850 Oliver PTO Shaft Bearing Number in reply to rrlund, 07-09-2013 15:32:33
Yeah I get that way too. Thinking of one thing and doing the other. LOL. I can break the bearing number and get it local and the oring. I'll have to order the snapring. This happened to me years ago. I was lucky. The bearing was ok and the snapring was there. I just put it back together. What would make this happen?
rrlund
07-10-2013 04:25:57
 Re: 1850 Oliver PTO Shaft Bearing Number in reply to eye4iron, 07-09-2013 20:00:15
Don't know. I'm wondering if the groove gets worn or the temper goes out of the snap ring. Mine came out a few years ago while I was picking corn. Only happened once and never again. You'd think if it was going to do it,it would happen when I was running something that turns harder,like the haybine,where it might bind up in a turn or something.
Daves392
07-09-2013 09:11:32
The AGCO parts breakdown lists the bearing part number as: 158363A Bearing - Fafnir 208KRR4; in addition you will want to put on an o-ring to seal it to the shaft: K5709 "O" Ring - 1/8 x 3-1/8 ID.
