Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: super 55 steering box
07-03-2013 16:40:34
I have a 55 steering box on the bench and went out to look for the mentioned holes. Couldn"t find "em. On mine, which has a worm shaft housing that is about 13 1/4 long to the top of the housing there is one hole that is plugged by a 1/4" screw that could be used to lube the upper worm shaft bearing. Is this some kind of a modification?
Super 55
07-04-2013 13:23:23
 Re: super 55 steering box in reply to rusty48ford, 07-03-2013 16:40:34
The fitting for the adding the grease is at the casting at the end of the steering shaft tube where it bolts to the steering gear housing. It is on the right side of the casting. It was originally filled with oil, but fill it with the corn head grease. The opening at the top of the shaft should have a grease zerk in it for greasing the top bearing on the steering shaft.
