Bearing sizes for light hubs
0liverkid
New User
Can anyone help me I have a set of light hubs to go on my Oliver super 77 but I don"t have any bearings does anyone have a part number so I don"t have to get calipers out and measure?
Thanks!
If you're going to take it apart anyway---most
bearings have part numbers on them.
But I presume that you need part numbers so
that you can have parts on hand when you take it
apart.
I had a suprise when I ordered the bearings from an AGCO dealer. There are 2 seperate part numbers cone and outer race. I ordered the part number from my parts book and only got the outer race. They were still cheaper than a local car parts store.
John Schoenauer
Worst case, if you have a narrow front end you can run on one tire if necessary. Pull one hub off to get the numbers off the bearings. Reinstall the hub and wheel or run with it off until the new parts arrive.
Oliverkid I copied this out of the AGCO parts book online:
1BS5013A - Bearing, Front Wheel Roller - Inner (Timken 26882 - 26820) (Row Crop S/N 320001 -) (Std. S/N 269001 - 15970)
1BS5014A - Bearing, Front Wheel Roller - Inner (Timken 26882 - 26820) (Row Crop S/N 320001 -) (Std. S/N 269001 - 15970)
I just looked at the bearing from the light hub of my 880 I think they are the same inner bearing 26882 and outer 2879 from the cone.
Hope this helps
John Schoenauer
I don't think he has any bearings in his hubs, hence he needs the numbers. It'd be too easy if he had the bearings and just needed to replace them...
Donovan from Wisconsin
Looks like I posted both inner numbers.
1 BS5014A2 - Bearing, Front Wheel Roller - Outer (Timken 2879 - 2820) (Row Crop S/N 320001 -) (Std. S/N 269001 - 15970)
John Schoenauer
