TractorLinks.com
Show Parts for Model:
Re: 880 timing
J. Schwiebert
06-27-2013 13:42:24
Your 2 "C' are to time the crank and cam gear. They have nothing to do with injection pump timing. Does your flywheel have a white timing tape marked in degrees? If not you have an older 880 and look for the FP mark. You need to line up FP when # 1 is on the compression stroke and you need to check the mark on the injection pump drive hub plus you need to be able to see the marked tooth on the injection pumps plunger drive gear.
