Anonymous-0
My 880 diesel has c on the crank and camshaft?
Its got a bosch pump and it has a pin and mark for it,And what is the top dead center or TDC on the flywheel have to do with anything?. Thanks!!!
Your 2 "C' are to time the crank and cam gear. They have nothing to do with injection pump timing. Does your flywheel have a white timing tape marked in degrees? If not you have an older 880 and look for the FP mark. You need to line up FP when # 1 is on the compression stroke and you need to check the mark on the injection pump drive hub plus you need to be able to see the marked tooth on the injection pumps plunger drive gear.
