TractorLinks.com
Show Parts for Model:
Re: 1650 Knocking sound
UncleD
06-11-2013 06:20:05
Seems there are a couple issues at least. I checked the motor mounts and the bell housing bolts, all are tight. Ended up tying the clutch down and that stopped most of the noise, but I still had a slight knock in the engine. Started shorting out the cylinders, each one would change the sound, but the 5th cylinder would stop the knock in the engine. It's not a loud knock, but it is noticeable if you sit and listen. But goes away about 1200 rpm and above.
Most of the knocking noise is either in the hydra or possibly the chain coupling as LP mentioned.
