TractorLinks.com
Show Parts for Model:
Re: 1650 Knocking sound
J. Schwiebert
06-10-2013 09:33:49
Three questions: If you hold the clutch petal down will the noise go away? If it does that would indicate at least to look at the Hydra-power. Are the rear engine mount bolts tight? Also the bolts that attach the bell housing? Third can you short out the cylinder and make the noise go away.
UncleD
06-10-2013 10:04:08
 Re: 1650 Knocking sound in reply to J. Schwiebert, 06-10-2013 09:33:49
I will try pushing the clutch in tonight to see if that makes a difference. I should have thought of that one myself lol. And check the bolts. What do you mean by "shorting out the cylinder"?
oliver90owner
06-10-2013 10:13:32
 Re: 1650 Knocking sound in reply to UncleD, 06-10-2013 10:04:08
Loosening the injector line - a bit messy and potentially dangerous if you are not careful. Diesel fuel at high pressure can penetrate the skin.
UncleD
06-10-2013 10:50:28
 Re: 1650 Knocking sound in reply to oliver90owner, 06-10-2013 10:13:32
Best to loosen at the pump or at the injector?
