Last year when I was cutting hay with the hydroswing on our 1855, I was turning on the headland and one of the tires on the haybine must have found a rut, causing a surge in the hydraulic system. After that, the hydroswing would creep in when swung out to one side. I think to the left. I swapped remotes and then it was fine for lifting, and the other one was fine for turning, but it was really hard for me to adjust to it.
Also worked fine last year for a 500 bu. manure spreader w/ hydraulic driven apron. I put a female coupler right in the drain plug on the back of the reservoir to return the oil straight to the reservoir, instead of back through the remotes. Worked great. I know it'll be a problem again on the haybine though.
What would I be looking for to fix it? A blown o-ring in the stack up? Would I need to remove the frame for the ROPS on the hydraulic side? It looks like it's gonna be a really tight fit otherwise to work on it.
Something I'd like to fix at some point, but it may not be until after 1st or 2nd crop.
I did just buy a new seat cushion for it though... Looking forward to putting it on.
Donovan from Wisconsin
