So if you read the link I attached you will see that have no oil pressure on my fresh build up of my 88. In that link I said I was going to pull the front cover off to make sure the plug for the pressurized oil line was behind the cam gear. Well tore it apart last night and it is indeed in the block... Does anybody else have any idea what could be the cause of my having no oil pressure? I am almost to the point where I think there is a crack inside my block somewhere and all my oil is squirting out and back into the oil pan. But the thing with that is I have consistent oil moving through the motor from top to bottom. Plug in the back of the motor?? I dont have any oil coming out my bell housing. Bounce all your ideas off me. It runs too good to give up. Email me if you want I dont care. There has to be someone that has been down this road before.
1st start no oil pressure
