TractorLinks.com
Show Parts for Model:
Re: 88 motor help
J. Schwiebert
05-30-2013 08:16:06
Quit guessing! Pull the pan and take an old refrigerant tank and make yourself a leak detector. Hook the detector, put abot 2 quart of oil in the tank. Hook a hose from the tank to the oil gallery like use the port the gauge goes to. Apply 15 psi of air pressure o the tank and look and see where your leak is. You did check your filter base for the restrictor being inplace?
Schim
05-30-2013 08:39:27
 Re: 88 motor help in reply to J. Schwiebert, 05-30-2013 08:16:06
The leak detector is something I will work on this weekend. As I read back to 2004 on this site the oil filter base kept coming up. I have the cast iron one not the aluminum one. I will swap the base from my 77 to my 88 tonight but cannot try it out until i put the front of the motor back together or until I get this leak detector built. Thanks J.
rp1555
05-30-2013 13:27:58
 Re: 88 motor help in reply to Schim, 05-30-2013 08:39:27
what kind of gauge are you using to check the pressure ? have you screwed low pressure gauges directly to the oil gallys on the block ?
Schim
05-30-2013 13:54:33
 Re: 88 motor help in reply to rp1555, 05-30-2013 13:27:58
I have an automotive type gauge from O Reillys automotive plumbed into the hole in the oil filter base. 0-50psi I think it is
