Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Oliver 550 temp guage
B A Star
05-28-2013 20:07:30
   The indicator on the dash has power supplied to it any time the switch is in the "I" position.  Power flows through the indicator then through a wire to the sending unit on the engine then to ground through the sender.    Take the wire off the sender and ground it to the engine block and turn the switch to "I".  The indicator should go all the way to hot side.  Should it not move you have an open in the wire some where.  Ground the terminal on the indicator that has the wire to the sender and indicator should go to hot.
