TractorLinks.com
Show Parts for Model:
Re: 550 PTO clutches
spmn
05-28-2013 07:23:29
This is fairly common---Someone installed the pressure plate in the position & you can"t get a straight shot at the set screw---You will probably have to disassemble the clutch pack while it's in the tractor to gain access---Just pull the long pins out & remove the through out bearing assembly, then unscrew the adjusting nut, then remove the pressure plate,& then you will be able to get to the set screw
HTH
Kent Gordon
Palestine, TX
Harry J. Case
05-28-2013 09:00:53
 Re: 550 PTO clutches in reply to spmn, 05-28-2013 07:23:29
Thank you Mr. Gordon, how many times have you bailed me out now ? At least three. Thanks again, I'll let you know how this turns out
