770 trans capacity
Mjfarms65
I bought the big shop manual and still cannot find trans capacity. I know it's 90w put 5gallons in already. How do u tell when full? Does power boost add to capacity?
trans holds 4.5 gallon and power booster holds 1 qt.I use 80 90 gear lube.Test plug is on right side just ahead of brake housing.
Park on a level area fill until fluid runs out of plug on side down by brake housing. replace plug then add one more quart of fluid.(tractor with power booster)
