TractorLinks.com
Show Parts for Model:
Re: Oliver 550 diesel lift pump
chucksoliver77
05-21-2013 08:31:47
stealer' you can get a new one from Kevin@ 518-522-5014, or a rebuild kit from korves@ 618-939-6681- NOTE: i think all the waukesha diesel lift pumps are the same or wiil work. hope this helps, chuck
steeler
05-21-2013 10:41:16
 Re: Oliver 550 diesel lift pump in reply to chucksoliver77, 05-21-2013 08:31:47
Thanks for the reply. I called the number you gave and asked for Kevin,. A lady answered and think she hung up on me? Now won t answer.
Are the rebuild kits fairly easy to do?
Thanks again!
Steeler
05-21-2013 11:04:07
 Re: Oliver 550 diesel lift pump in reply to steeler, 05-21-2013 10:41:16
Ok, she just call back. Says no Kevin at that number?
chucksoliver77
05-21-2013 12:36:51
 Re: Oliver 550 diesel lift pump in reply to Steeler, 05-21-2013 11:04:07
some days it seems i just can't read lol, the correct # is 518-522-9307. sorry about that, Chuck
Steeler
05-21-2013 16:24:23
 Re: Oliver 550 diesel lift pump in reply to chucksoliver77, 05-21-2013 12:36:51
Thanks! I talked to Kevin. He said he didnt think the 550 diesel came with a lift pump, but the 6 cyl did. Suggested I take it off and let it gravity feed. I m pretty sure my pump is factory though. Either way, he said the lift pumps like that are no longer available.
I guess I ll be trying my hand at a rebuild kit!
Thanks for all your help!!
Mike (WA)
05-22-2013 01:52:16
 Re: Oliver 550 diesel lift pump in reply to Steeler, 05-21-2013 16:24:23
My 550 diesel definitely had one- it started leaking into the crankcase, so I replaced it with an electric fuel pump from NAPA- works fine.
Dick W.
05-21-2013 21:45:11
I don't know what your pump looks like but on my super 55 and on my 550 engine the pumps came apart really easy. Mine didn't leak into the oil but both had one check valve out of place. Make sure to set them in the proper direction and "stake" them to stay in place. Your tractor won't run right without the lift pump. BTDT.
Steeler
05-22-2013 19:28:20
 Re: Oliver 550 diesel lift pump in reply to Dick W., 05-21-2013 21:45:11
Thanks guys. I ordered the rebuild kit.
I thought about doing away with the mechanical pump and juast using an electric one but I want to keep it as original as possible.
Ive been thinking of selling it to get something a little more parts freindly.
But I LOVE this tractor so much!!!!!!!!1
