1650 hydraulics
ohio dick
Was bailing today dropped a bale started next one tailgate alarm went off latched gate and it came open again. switched hoses to other side works ok. what would go bad that left side wont hold pressure but right side will.
Well first of all is this a single or double acting cylinder? Now for the good news, what ever your problem is it is in the top cover. Your description does not make a whole lot of sense to me. does your baler also use another cylinder for some other function?
baler uses double acting cylinder for tailgate. the latch is teed in to one side of tailgate cylinders. if you loose pressure latch opens.
Well like I said the problem is in the top cover. Take it off and take the check valves out. I would look for a broken spring first.
