Oliver 1850 hydraulics
P. Flint
New User
I recently purchased an 1850 gas w/ front loader and the adjusters under the seat are leaking a lot and the left side restrictor valve is damaged too much to adjust. Can the leaks be stopped, and replacements parts purchased? I believe it is a 1969 sn.198831-528/model# 385-21026. Any help appreciated, thanks!
You asked: Can the leaks be stopped? The answer is yes. There are several ways to do this. Can parts be purchased? Don't know hard to check on Sunday. Used parts are available that will work are available.
