Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: '55 Series Violent Shaking
05-17-2013 08:11:04
Jim the high side of my hydropower is slipping and it shakes bad when I first shift it. It does not shake in UD. I only have the 2 speed but it sounds like the problem you are having.
05-17-2013 09:40:18
 Re: '55 Series Violent Shaking in reply to hd6gtom, 05-17-2013 08:11:04
Did you check the transmission input shaft for excessive play in the front bearing at the chain coupler sprocket?
i had a 1855 with a bad shake and found upon engine removal/rebuild a lot of play in the tr input shaft.
I took out most of the shimms to get the preload to be were it should be.
The shake was gone.
Then again i had rebuild the over/under as well for good measure altough i found nothing wrong in it but the sprag was about to fall apart when i took it out(i could save that one as well by fashioning some brass rings on my lathe to hold it together and get the sideplay out).
I put 2500hrs on it problems.
