Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: BAD DAY:(((
Zach Scherf
05-15-2013 19:18:00
How can I tell if it is just the water pump I removed it today along with the oil cooler
Galen Houk
05-16-2013 18:29:30
 Re: BAD DAY:((( in reply to Zach Scherf, 05-15-2013 19:18:00
I am no expert but my brother had the same problem with water in the oil. First if it is the intercooler there shuld be oil in the water, not water in the oil. Second it will be very hard to tell if the pump is bad with it off. His poured water into the oil and looked fine when off. It's too late now but the first thing you do is clean out the weep hole and see if water comes out. He had to drill the hole out because it was so packed with dirt. No water came out even then. Next you take the pan off and pressurize the system and look for where the water comes in. You might be able to press the pump apart and look at the seal inside.
