TractorLinks.com
Show Parts for Model:
Re: 310 gas crankshaft
oliver90owner
05-07-2013 14:53:59
The answer lies is in the type of lubrication you have.
The 310 has pressure lube? blocking the oilways will reduce lubrication to zero?
Other than that, not really sure what you have.
IndianaOllie
05-08-2013 10:03:25
 Re: 310 gas crankshaft in reply to oliver90owner, 05-07-2013 14:53:59
Using a 77 2in rod on a 310 crank.
Goldsburg
05-09-2013 07:41:31
 Re: 310 gas crankshaft in reply to IndianaOllie, 05-08-2013 10:03:25
Ollie -
You should tig weld the holes of the top of the 77 rods shut and use the pressure oiling of the 310 crank, if possible. If the stroking has "eliminated" the oil galley in the crank, I would recommend having those galleys re-drilled. Pressure fed is better than splash, especially at high engine speeds and loads.
Regards,
Goldsburg
