ol 1650 rear tires dual mounting
jim_uny
have oliver 1650. want to use my snap on duals.
came with eye hooks in wrong location. how can i use duals ? what are my options ?
I would not hook a set of duals to the wheel weights, You will never keep them tight. You wheels are on backwards so the studs you would use to put the eyes on are on the inside, So you can take the stud or bolt out of center casting ware the wheel clamp is and replace it with a longer bolt or stud so it sticks out to the outside and screw the eyes on them. Or if you have open holes in the wheel casting you can put a bolt through them and screw the eyes to them. This is what I did to put duals on my 1550. Bandit
