TractorLinks.com
Show Parts for Model:
Re: 1961 1800A gas - cooling - still confused
ollie gm
04-29-2013 14:31:15
Quick thought:
Make sure you don't have an air lock in your engine. This effect has the air trapped in the engine and the radiator full of water. A t-stat with no bleed hole and/or installed backwards can cause this. I have seen home made gaskets block the bleed hole making the air removal take forever.
Don't run the engine too long because when the steam eventually opens the t-stat and causes red hot cylinder walls to be slammed with cold coolant, things move around fast.
Good luck!
