S77 Energy cells
dep
Looking for 6 energy cell bodies for a S77. Pulled the caps and found the main cell body is not there. For some reason last owner must have taken them out?
Energy cells out of any 4 cylinder Oliver diesel as well as a 77,770 or 1550/55 are the same. It must really start hard!
Yes, always started hard since I got it. Took them out to celan after having injectors done. The celbody has a small orifice? Want to make sure I am seeing tis right. Pull the threaded plug and have the piece that goes in the cap, the piece you grab with theneedle nose, then nothing. I can run a 12 ga shotgun brush straight thru there. This wouldnt be the case if the cell body was in there, right??
