TractorLinks.com
Show Parts for Model:
Re: super 55 remote cyl valve
Super 55
04-24-2013 12:43:01
There is a little more involved than that if your tractor is prior to serial number 23 131-500. You need the stand pipe to increase the capacity of the hydraulic oil, you need to relocate the breather to the top of the transmission cover, and block off the old breather location. The stand pipe has a gasket at each end, male threads to screw into the transmission top and threaded on the other end to receive the dipstick. There are two fittings and two tubes that pick up and return the fluid. Check your serial number and if you need them, make sure you get those from the parts tractor too. If you need to do the field conversion, let me know and I can email you the instructions out of the manual.
