TractorLinks.com
Show Parts for Model:
Re: 77 build up
doug boll
04-21-2013 07:42:29
I figured the distance from the center of the pin to the top of the piston on a 77 piston is 2.295 so if I take off .500 for half the stroke that leaves 1.795, exactly the comp. distance of a L216F power forged piston for a 230/283 if my math is correct, I will look at the 318 pistons though, a person still has the option of using an offset pin bushing to get it exactly right. Would this set-up make 80-85hp if everything was done correctly?
SS409
04-21-2013 08:04:07
 Re: 77 build up in reply to doug boll, 04-21-2013 07:42:29
the reason I mention 318 pistons, is they have wrist pin clips stock. you can offset the bushing quite a bit, up, or down to perfect rod centerline distances. cyl head porting alone, with bigger valves to help feed it. 75-80 out of that ci could be an underestimate. I had a old 77 I bought for 500 a long time ago. dyno 42hp all day long. fun lo gear tractor.
doug boll
04-21-2013 15:54:12
 Re: 77 build up in reply to SS409, 04-21-2013 08:04:07
the 526P piston for a 318 also has no valve reliefs for compression loss, the little difference in comp. height can be made up in the stroke or or offset bushings or shave the piston a few thousanths, my restored 77 with 3.5 pistons will run 41hp at rated speed, 44 crankdown, were building a puller out of a 1950 $400 dollar runner we bought at a farm sale last summer
