Jake Collie
The steering wheel on my 55 goes up and down when I turn it so I guess that means I need to replace the bearings. Are there 2 or 3 bearings? It looks like there is one just under the steering wheel and one on the bottom end of the steering shaft with part of it inside the gear housing but is there another one about 3/4 of the way down the shaft inside the tube? Does the whole steering gear assembly need to be removed from the tractor to replace the bearings or can the top one be replaced without removing it all? I suppose it makes sense to remove the whole thing and replace all bearings anyway.
