Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Super 55 steering gear bearings
Dick W.
04-20-2013 19:24:23
I just did one. Take it off the tractor so you can clean it out. There are three bearings. The bottom one with a cup in the housing, The same bearing on the top side of the worm with the cup in the bottom of the upper tube, and the bearing under the steering wheel. The bearings are hyatt bearings and replacements are available. Look for Ford steering gear parts, the lower bearings are the same. I got the metal bearings not the plastic looking ones. The one under the steering wheel I got off an ebay seller. Make sure to time the two shafts properly when you assemble the gears.I replaced both of the lower bearing cups since they come as a set with the bearings. I also found new seals for the sides where the shafts come out to the first arm. Have fun with your "55"!
jake collie
04-21-2013 05:31:57
 Re: Super 55 steering gear bearings in reply to Dick W., 04-20-2013 19:24:23
Thanks much!
