1755 rear end fluid
Anonymous-0
Hi guys,
Where do I check the rear end fluid on my 1755 Oliver? Is it the two small plugs on the right side of the pto housing. The top one being the correct level? Also where do I add if need be? Thanks for your help
Top plug is for fluid level when sitting level. Lower plug is the minimum fluid level when performing stationary PTO work.
Fluid is added by removing the breather on the left side of the PTO housing.
