Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Power Beyond on a White 2-70
Mike (WA)
04-14-2013 18:34:19
On my Oliver 1550 (which I no longer have), I'm thinking the hex headed plug on the right side, highest up, just under the seat, was the power beyond port. There would be a 3/8" threaded hole inside, which you plug, then the juice is diverted to the outside port. But I'd recommend getting a book to find out for sure. And I don't know what you do with the present hookup on the left side- but it almost looks as if the two sides are symmetrical, and you could use either side. If they look the same inside, I'm thinking you could switch the internal 3/8 plug from the left to the right, the outer 1/2 plug from the right to the left, and the hoses from the left to the right. Same with the return line. Clear as mud, right?
I'm curious about that big plug on the right front corner of the housing- anybody know what it is?
90 Percent Retired
04-15-2013 05:20:04
 Re: Power Beyond on a White 2-70 in reply to Mike (WA), 04-14-2013 18:34:19
I'm pretty sure that is the main relief valve. There are no 3/8 internal threads on the RH side of the top cover, and no place to return the oil to the system. If you looked at the schematics in the Oliver shop manual and understand what passages the oil is routed through then you would know why the power beyond needs to be plumbed by the book. It has an open center, not a closed hydraulic system so you cant just get pressure from any plug you see.
Mike (WA)
04-15-2013 12:41:54
 Re: Power Beyond on a White 2-70 in reply to 90 Percent Retired, 04-15-2013 05:20:04
Sounds like you know what you're talking about- looks like he's stuck with what he's got.
