TractorLinks.com
Show Parts for Model:
Re: 354 Perkins
Mitch Poindexter
04-14-2013 17:11:21
While we're on this topic, I swapped one over during Christmas, and when dad finally had a chance to start it the other day, we don't seem to be getting oil to the front crank bearings, back ones are oiling fine. Massey motor was pristine top and bottom, so I'm assuming I missed something when I swapped all the Oliver pieces over. Had to knock out the oil plug to switch the cooler over, so I know that's not it, but we can't seem to figure out what I screwed up. Any ideas?
rrlund
04-14-2013 17:54:48
 Re: 354 Perkins in reply to Mitch Poindexter, 04-14-2013 17:11:21
Did you change the tube inside the engine that runs from the oil pump? It had to take the oil over to the other side to where you relocated the filter base. That's the only thing I know of on the inside.
Mitch Poindexter
04-14-2013 20:59:55
 Re: 354 Perkins in reply to rrlund, 04-14-2013 17:54:48
No, I didn't. Is that something that can be done with the pan off? Honestly, I assumed that the oil passageways in the block were common since the other side had a plug that I had to remove.
rrlund
04-15-2013 06:43:11
 Re: 354 Perkins in reply to Mitch Poindexter, 04-14-2013 20:59:55
Ya,you can do it with the pan off. Getting the pan off is another thing. Not a lot of room up front between the pan and frame. Best to use a 3/8ths drive shallow socket and a swivel ratchet.
