Todd Hertel
New User
Looking for tie rods ends to fit a Co-op E4 SWF with part numbers TO-8870 and TO-8869. I can find parts for the AWF with TF-10800 and TF-1802 ends. Does anyone know if the tapered pin that fits into the steering arms the same?
Developing a power steering system that will require custom built tie rods but I need tie rod ends with tapers to fit the outer wheel steering spindle arms. No matter if R or L threads but would be ideal to find the correct taper with 3/4 x 16 threads or 7/8 x 14 threads. I plan on using tube inserts as found in the link below.
http://www.wfoconcepts.com/cr/Tube-Inserts/3207
Thanks
T.W.
Thanks
T.W.
