Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1755 engine problems
young tractor
03-28-2013 19:58:20
I work on all my machinery's clutches, pto's, bearings, etc myself, but don't have a ton of knowledge on engines. If it is not to much to ask. How do I set up a bearing leak detector and how do I pressurize the cooling system. I am a small farmer getting started on a low budget. I would really like to try to figure the problem out without sending it in to a shop if at all possible. On a side note I noticed the hydraulic oil was pretty low on the tractor when I was giving it the spring maintenance. Is it possible for the oil to get in the radiator through the hydraulic oil cooler? Also I have been plugging the tractor in for a couple hours before starting it. I also doubt that would be part of the problem. I really appreciate your help.
bison
03-29-2013 21:40:50
 Re: 1755 engine problems in reply to young tractor, 03-28-2013 19:58:20
Quoting Removed, click Modern View to seeThere are universal coolingsystem pressure testers on the market.They are not expensive.
The kit consists out of a Rad cap and hose connected to a handpump with a gauge.
If you have a 310 waukesha in there i suspect a slight leak in the head gasket between a waterjacket and the oilgallery that feeds the valvetrain.If the engine oilcooler is in the rad it could have a leak as well.
A leak in a sleeve 0 ring would only pass coolant to the crankcase but no oil to the cooling system.
The hydr system is seperated from the engine or cooling system but could however leak into the transmission by various ways(check tranny oil level for being high) or has a slow external leak trough a bad hose or so.
A drop of oil a min will leak a lot of oil over the winter.
J. Schwiebert
03-29-2013 13:32:17
How can we contact you?
Copyright © 1997-2015 Yesterday's Tractor Co.
