TractorLinks.com
Show Parts for Model:
Re: 1755 engine problems
J. Schwiebert
03-28-2013 19:16:57
When the 1800 B series would do that there was a double problem. Worn main bearings would let oil pass by the sleeve sealing O-rings. What I would do first is drain the oil pull the pan rig or a bearing leak detector and see how much oil passes by the main bearings. Part 2 would be fill the cooling system with antifreeze. pressurize it and see if you have any leakage. We have an IH in the shop at the minute that dumped some coolant in the pan. As long as the tractor was inside the shop it would not leak, set it outside overnight at about 20 degrees and we had pink snow in the morning. One of the O-rings on #5 sleeve leaked. Questions. Head bolt torque and valve settings are not the same as for your 310 (1850) gas.
