TractorLinks.com
Show Parts for Model:
Re: White 2-105 5.8 /354
J. Schwiebert
03-23-2013 09:04:57
I would need to look it up. I am used to the 354 in the 1850 tractors. But once if you set the timing on the gears don't turn the engine over as those timing marks do not turn the engine over as the timing marks do not line up every 2 turns like in most engines. The pump drive is timed by removing the injection pump and timing the drive not the drive gear. Also remember that all 2-105 tractors use a 354 Perkins, but some tractors use a dot one engine,later ones use a Dot 4 engine and specifications are not the same for the 2 different engines. You better look at your engine number and tractor serial number and post them.
grace123jd
03-23-2013 10:48:09
 Re: White 2-105 5.8 /354 in reply to J. Schwiebert, 03-23-2013 09:04:57
My dad said it's a Dot 1.. and I listed the engine numbers above..Thank you..
