Pics-Co-op E3 Distributor Question
1206SWMO
I recently purchased a Coop E-3 missing the distributor..The owner found a Autolite AD 4101A 9Z distributor in the shed that he thought might work..Its the one on the right missing the drive gear..It wont turn over..Is this the correct distributor?
Is the distributor for a E-3 Coop one of a kind or will one from another tractor fit? What about the drive gear?Is it one of a kind?
The distributor on the left is from a VAC Case and looks similar..
the E-3 uses a AUTO-LITE 1AD6003-1A 4 cylinder set at .020 gap I have some of these if you need one in western Penn. Irv
I don't think either one is for the E3. The Budas I've seen have the gear on the oil pump with slots to engage a tang on the distributor shaft. I would post a pic but I haven't figured out how to do it on this site. Send me your email address and I can send you some.
