Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Oliver 1800 or White 2-70
J. Schwiebert
03-17-2013 18:47:17
On the 1800, is it gas,diesel or LP. Is it an A B or C series? Is the 2-70 gas or diesel? If it is an 1800 A series diesel the 2-70 if it is a diesel will have more power plus use less fuel. If the 1800 is a B series the 2-70 will have better hydraulics plus use less fuel if both are diesels plus the 2-70 will have better power steering. If the 1800 is a C series then things change a little bit. Plus the 2-70 has most likely a 3 speed, over under & direct while the 1800 will be under and direct only. What are you going to do with the tractor. Around here you would use something like that to spread fertilizer or run an auger or mow along the road.
