Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Cockshutt 570 DD298
Irv B
03-16-2013 16:35:58
most of those stile blocks are reversable. Simply by reversing the crank and cam shaft and all the external parts. You do have to change the cam gear though when you do that because youve changed the rotation direction. That being said you should be able to take your front mounting covers, rear mounting covers, and a few other parts and convert the engine. You still need to make sure it turns right way for your tractor, IE injection pump and cam shaft is on left side. What is wrong with your motor? What does it need to rebuild it? Irv
Steve Phelps
03-17-2013 13:48:16
 Re: Cockshutt 570 DD298 in reply to Irv B, 03-16-2013 16:35:58
I spun a main brg.The crank needs work and one new sleeve on that hole.To do it right I think I should sleeve all 6 or pistons on the other five.It needs new valves and injector cups.The head and block are fine.Oil pump seems ok.If I replace all 6 with new pistons and sleeves I am looking at $3200.00.This does not include new oil pump(extra $395.00.
Thank you for the answers.
The used tractor was new to me and used oil.I neglected to check oil on a busy summer and was working it hard pulling a belly dump from a ditch.I was on a side hill and low on oil.
After tear down I discovered blow by,1 or 2 exhaust ports 3/4 plugged with carbon.I think the engine was ready for overhaul.Some say not to weld a diesel crankshaft.The machine shop its at,say he has no problem.
Any more info would be appreciated.
J. Schwiebert
03-18-2013 16:24:33
 Re: Cockshutt 570 DD298 in reply to Steve Phelps, 03-17-2013 13:48:16
You can weld diesel cranks: HOWEVER the process is different than welding a plain jane steel crank. Where are you located? I can point you toward some shops that do diesel cranks. Years ago we had a crank welding class where I worked. We even had a special class once for the Cat people on welding 3406 Cat cranks. How can I contact you? I think your ER motor uses a larger wrist pin so that means different pistons and rods.
Irv B
03-17-2013 16:25:49
Tony you are right, I was trying to keep it short and go from memory. My email is for those who need it. phone 724-253-4285. Steve,I have heard very little issues with welding one jernal but all most every ones says never weld multiples or the whole thing. There are shops that claim to be able to do it but they also have to re-heat treat it. Where are you at? I mite be some help on those parts for a rebuild just depends on what you want to do. Irv
Tony Sha
03-17-2013 10:11:28
I just went through this on my 570. If you take a R.H. cam engine and make it a L.H. cam engine the crank and cam stay in place and turn the same way. It is the block that you are spinning 180 degrees. The oil pump drive gears are cut opposite on the camshaft. I found this out the hard way when I assembled my engine. I went to install the tach drive gear and it wouldnt go into the cam gear. I had to pull the cam out of my old engine and install it in the new one. I was able to use the timing gear but it was not marked for use in a L.H. cam engine. I had to count teeth and make my own mark. I also had to use the oil pump driven gear out of the old engine. Hope this clears it up for you.
03-17-2013 05:57:03
Irv; do you have an email address. I have some questions about sleeves for D298. Thanks my email is open
