super 55 steering gear bearings
Dick W.
Does anyone have Timken numbers for the upper and lower thrust bearings and cups for the steering gear shaft? I removed one cup and it is a Hyatt 10790 as near as I can read it. The numbers I got on the Agco site don't cross over in my industry web sites. Thanks for any help.
I've found that most bearing MFG's use a universal bearing part #, so chan ces are good it'll match right up with Timken's number for the same bearing.
If you can measure, it, you can also go to McMaster.com and cross it by dimensions.
Donovan from Wisconsin
Super 55 parts book shows the folowing:
The upper and lower bearings and bearing cups are the same.
Oliver # is L-6769, it is Hyatt #10790S Description: Cylindrical Roller Bearing - Roller Assembly
Oliver # is L-6770, it is Hyatt #10790Z Description: Cylindrical Roller Bearing - Outter Race
Description and supplier number is from Corporate Bearing Cross Reference Book.
