Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Some of your smarts
[Return to Forum]
ollie poor
03-04-2013 12:22:00
69.63.4.10
I purchased a 770 gas with a bad engine to have something to work on. I picked up a diesel engine from an 88 reasonable and want to repower the tractor with this. The response from my previous post stated that the 88 is a little longer and the shafts and coupler need to be shortened. Has anyone on this site repowered with a diesel? Any advise would be helpful.
[Reply]   [No Email]
chucksoliver77
03-04-2013 16:09:46
71.0.111.175
 Re: Some of your smarts in reply to Bud Tierney, 03-04-2013 12:22:00
you could slide the 88 engine forward the required amount and drill new motor mount holes in the frame\engine. that's what i did when i put a 310 in my 77, both the drive shaft and pto worked without cutting. you may have to slide the radiator forward a little and that can be done by simply drilling new holes in the fan shroud. i think if i had to do it again, i would take the fly wheel off the stock engine before i took it out of the tractor and take a piece of steel, lay it across the tub against the engine plate and drill and bolt it to the tub and then mark where the engine plate hits the new piece of steel for perfect alignment, then drill your new mount holes. you may have to notch the piece of steel that you are using for the alignment to clear the crankshaft. chuck ps, when i put the stock 77 engine back in the shafts were good to go
[Reply]  [No Email]
ollie poor
03-04-2013 13:52:33
69.63.4.10
 Re: Some of your smarts in reply to ollie poor, 03-04-2013 12:22:00
The bellhousings the same?
[Reply]  [No Email]
ollie poor
03-04-2013 13:49:24
69.63.4.10
Thanks for the help. Hopefully I can get some pictures.
[Reply]  [No Email]
Dick W.
03-04-2013 12:42:59
174.54.58.169
I re-powered my 57 super 55. I know that isn't the same as you have but it was really easy to do on mine. Took out a gas engine, put it in my 66 and installed a late diesel in the 55. I find that kind of work a lot of fun.
[Reply]  [No Email]
rrlund
03-04-2013 13:07:42
207.241.137.116
 Re: Some of your smarts in reply to Dick W., 03-04-2013 12:42:59
I went the other way years ago. Put a 66 gas motor in a Super 55 that had been a diesel.
I think you'll find that 770 motor is about an inch shorter than the 88 motor. Pretty sure the motor mount bolts line up,the difference should be the rear of the block behind the rear motor mounts. I think the larger issue is going to be the PTO long shaft. With just an inch of difference,you might have enough spline there on both ends of the driveshaft. It's possible that if it still ends up being a little too long,a machine shop could take a little off the end that goes in the clutch and pilot bearing.
[Reply]  [No Email]
OLarry from MD
03-04-2013 15:15:41
97.73.64.155
 Re: Some of your smarts in reply to rrlund, 03-04-2013 13:07:42
One fellow i talked to said he just put the rear bolts in the holes and the shafts fit.He allso claimed they didn't drill new holes for the front mounts either.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
