| Oliver, Cletrac, Co-op & Cockshutt Tractors Discussion Forum |
Topic: 8.3 swap
[Return to Forum]
| Author |
[Modern View]
| Garrett Knight
02-26-2013 19:18:40
184.9.241.121
Will an 8.3 fit in an 1850 or 2-105 tub? |
| The tractor vet
02-27-2013 06:30:09
76.212.232.79
Re: 8.3 swap in reply to Garrett Knight, 02-26-2013 19:18:40
| Boy i do not think so as it is a lot bigger then a BT . |
| Garrett Knight
02-27-2013 14:08:33
184.9.241.121
Re: 8.3 swap in reply to The tractor vet, 02-27-2013 06:30:09
| The tractor vet
02-28-2013 08:00:20
76.212.232.79
Re: 8.3 swap in reply to Garrett Knight, 02-27-2013 14:08:33
| yea we are that is what came on it . we have a 13 inch opening in the bottom and this is fine and the width at the top is fine but on a small tub she is not going to fit. The Herc engine is about the same size as the 8.3 cummins . the bellhousing on the herc is a little narrower and sofar as we see it the rea mounts will have the bolt that goes down thru dead center of the side plate that mounts to the Type 2 bellhousing . The ft. mounts will be of a L shape . the oil pan is the big stumbling block due to ft. drive shaft . After and hour with Cummins yesterday on the phone we found out that we MUST keep no less the six gallons of oil in this engine at all times (1) due to cooling of the oil as oil temps must be kept at around 215-240 degrees and (2) there is three gallon of oil in suspension while running at high idle and that leaves three gallon in the pan . So here we will have to flare out the bottom and extend to the read to make up for what we have to cut out to clear the drive shaft. . Plus we may have to add a ft. sump with a flow back line . So since we HAVE to cut the oil pump pick up tube and shorten it and add 2 1/2 inches in length finding the correct tubing was the next problem and that was a easy cure . This IS NOT A HARD swap it just takes a lot of running and lots of phone calls . Also it is not what you know but WHO yo know and where to go to get what ya need and where to look. Had this been a two wheel drive she would have been setting outside the shop by now and other then motor mounts everything ya need is OFF THE SHELF parts and a check book. Once we are done with this one we are looking for the next one as we will have this one down and that will make the next one a lot easier . Plus where are you going to have a 200 Plus Hp. tractor for UNDER 8500 bucks . Yea ok it does not have A/C and yea at this time it does not have a 30 or 50 gal. a min and 2500 psi Hyd system BUT with a little more work that can be added . Just like heat in the cab as we are going to add heat and we are going to put it up in the cab blower housing add a cab kit and add in some rubber mounts and a couple gallon of paint and we have a tractor that will do the job and we do not need a lap top to figure out what is wrong. We have even talked about doing a Cummins swap into and older small 4wheel drive bend in the middle that had a V8 in it or maybe a 4366 and replace the 466 with a 8.3 . We are having way tomuch fun . |
| Garrett Knight
02-28-2013 19:24:23
184.9.241.121
Re: 8.3 swap in reply to The tractor vet, 02-28-2013 08:00:20
| I put a 5.9 in a 1955 cockshutt it was easy and turnd out nice I have 2-105 tub I was going to see if 8.3 would fit in it I have 1755 cockshutt to put a 5.9 in for a feed grinder tractor |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
