Three speed question
Anonymous-0
At the last pull our 1655 when I shifted from direct to under she stopped dead. This is the first time this happened was wondering what to look for or check when we take it apart.thanks for any help.
YOUR SPRAG CLUTCH IS GONE YOU WILLHAVE TO CHECK SHAFT FOR WEAR TOLERANCE ,NEW CLUTCH MIGHT HELP FOR A WHILE
the problem may be the over under itself. we pulled with a 2150 and on one of its last pulls we shifted from direct to under and it stopped dead as well, and we knew the hydra-power was getting worn.
