John Schoenauer
A couple of questions about the 880 that I am working on.
Can I replace the oil pan gasket without pulling the motor?
I am setting up one side of the hydraulic unit to operate a single acting cylinder. I have the momentary restrictor but the pal nut was gone and I need to know where the standard setting should be.
This tractor has the filter conversion on the transmission, it has a pressure gauge that I will need to replace. How much pressure would the pump put out so I can get a gauge that will work.
That’s all the questions for now.
Thanks
John Schoenauer
Thanks
John Schoenauer
