Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Connecting rod siezing the motor
[Return to Forum]
sdc eastern ia
02-23-2013 12:07:22
69.63.4.10
Well today I made a set of shims from a pop can. Actually I'm kind of proud at myself even though it didn't change a thing. .005 shims hand tightened the nuts pretty snug and the crank won't spin. Back them off just a little and it spins. I've taken all your advise ie. backwards cap, wrong end caps (a possibility although the rest are fine) used plastiguage and had satisfactory clearence before the shims. At this point I'm just trying to get the correct answer. I will not be using this motor as of now.
[Reply]   [No Email]
mattwillson
02-25-2013 16:41:59
216.198.139.38
 Re: Connecting rod siezing the motor in reply to sdc eastern ia, 02-23-2013 12:07:22
I had a crank ground 10 under once that the cheeks were interfering with rod bearings. Not cool, big block dodge cranks are hard to find. Ended scrapping it and getting another crank done up.
[Reply]  [No Email]
roy drewis
02-24-2013 11:08:42
70.199.198.106
Are you sure all the rods were installed the correct way and one isn't backwards. Don't know if you replaced the pistons on the rods and maybe installed it wrong. I have come across some rods where someone in the past stamped the rods on wrong side. Rule of thumb is that the numbers on the rod should be stamped to the camshaft side. I'd check each cylinder seperately by loosening each one and re-torque to see which one or if all are causing the problem. If all are causing it you could have mis-labled bearings also. plasti gauge will help you also once you find the bad one. If they all gauge the same then your crank; if reground could be ground wrong or the bearings are incorrectly fitted. I usually ask to have the machine shop fit the bearings to the crank if I'm regrinding a crankshaft. I had one reground once and they then could not get the bearings so the monkey was on their back,they didn't charge me for the grind. But I still ended up then with crank I couldn't use and had to locate another to replace it.
[Reply]  [No Email]
Dick L
02-24-2013 05:25:02
50.51.184.132
If you put new bearing inserts in without grinding the crankshaft and having the bearing inserts matched to the crankshaft you can have the new inserts pinch in on the crankshaft. If there is not enough room the rod is not going to expand. (If) that is the problem the bearing inserts need to be measured and the ends filed to fit.
[Reply]  [No Email]
e
02-23-2013 19:12:06
69.66.234.201
Sounds like it's time to buy a calipers or better yet, a micrometer. If you continue down this path of just guessing at what to do, you'll end up with a rod hanging out of the block plain and simple.
[Reply]  [No Email]
PORKY B
02-23-2013 18:49:13
67.58.215.226
you will find your rods big end is out of round have it resized
[Reply]  [No Email]
sdc eastern ia
02-23-2013 14:28:59
69.63.4.10
Monday I will look for numbers and even turn the rod around. I used 4 .005 shims on each side and still have .003 clearence. I've never seen such a thing.
[Reply]  [No Email]
el6147
02-23-2013 17:09:47
50.124.60.237
 Re: Connecting rod siezing the motor in reply to sdc eastern ia, 02-23-2013 14:28:59
if you are confused as to why your plastigage always shows as being .003 its because it will only crush so far, as to what your problem is I don't know but one thing to check is the size of the rod with no bearing insert installed , the rod bore may be under size . I had a machine shop resize four rods for me for a 1010 John Deere and every one of them was .010 under and the first one that I installed showed that there was .003 clearance with plastigage also, first one I installed and torqued down locked the crank up , the shop tried to convince me over the phone that my bearings were not correct for the application. Shop tech doing the work read the mic incorrectly when he honed them .
I purchased a bare block for a 1650 from a salvage yard about 10 years ago and when I installed all the bearings and the crank and torqued the mains the crank would not turn . one by one I loosened each of the mains until the crank would spin , turns out that one main journal was under size from all the rest and I had to have the block line bored to fit the bearings properly . I have no idea why one was smaller than the rest but if I would Have to guess I would assume Waukesha had some bearings that weren't sized correctly and rather than scrap them they just under bored the block and used them up .
[Reply]  [No Email]
RWT
02-23-2013 14:15:38
50.103.187.176
I had a 1750 once that didn't feel right when torqued even thought the rod was good and the clearance was good.
I put different inserts in and the problem went away. I still have those inserts and still don't know what was wrong with them.
RT (my 2 cents)
[Reply]  [No Email]
gary Spitznogle
02-23-2013 13:27:38
207.199.242.7
Check and make sure the 2 digit # on the cap and rod match. This is not the Cyl# But a # like 32, 54 it will have 2 digits. If this is ok with the rod tight take a flashlight and look at the wrist pin and see if the rod is pushed to one side or the other of the piston if it is the rod needs turned a half turn as it is offset. If this is all ok you probaly have a bent rod which is binding.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
